Results 1 to 10 of 14
Thread: Wiring Diagram
    Allens Rivulet, Tasmania
    Wiring Diagram
    Hey all, just wondering if any of you guys have a wiring diagram, or a link to a wiring diagram, for a mk1? let me know.
    Zac
    Boronia VIC
    You'll have to be a bit more specific than that. I've got about about 5 different workshop manuals covering the mark1's. Each of them have about 4 or different wiring diagrams and none of tham co-respond! If it's a specific question you've got, ask away and see what answers you get! If you can narrow down the specific model a bit I might be able to scan some up for you when I get to work on Monday.
    I have a GLD with a MKII K-Jetronic motor which makes the wiring even more interesting!
    Happy hunting!
    Pete
    syncro Guest
    What do you need to know?
    i need the basic wiring diagram for the wiring to the carb really, just to make sure everything is where its supposed to be, and to connect a few loose wires.
    syncro Guest
    Black wire (15) live with ignition on goes to auto choke, fuel cut-off
    Brown wire (31) is earth
    Camden, Sydney
    Good work guys, better value asking you blokes than traipsing through the books. Ive got loads of manuals and they all say different things.
    Boronia VIC
    If it's carby wiring that's the problem don't forget the earth cable from the carby to the motor. The carby sits on a rubber mount and if you don't earth it you can get all sorts of strange intermitant faults when the current has to find a path back through the accelerator cable or something else . Most of the VWs I've looked at seem to run all the +12v ignition carby connections from the positive side of the coil.
    Pete
    syncro Guest
    Quote Originally Posted by Peter Jones
    Pete
    Golf coils are not 12V, Beetles are.
    Boronia VIC
    Really? I'm pretty sure the one on my 1600 is a normal 12v coil. Kettering style points and everything. I didn't find any resistors along the path.
    My 1800 has electronic ignition so I didn't really consider that. I'm still repairing wiring on that car and haven't gotten as far as the engine bay.
    What voltage are golf coils? You've got me curious now, I'll have to make some measurements and read some diagrams.
    Pete
    syncro Guest
    The cable from the fuse panel to the coil is a resistor. I removed mine when I put the electronic ignition on and replaced it with a copper cable.
Similar Threads
  1. MKIV Eurovox wiring chart
    By mikinoz in forum Mk4 Golf & Bora and New Beetle
    Last Post: 27-06-2017, 12:04 AM
  2. Wiring loom
    By rayray086 in forum Mk3 Golf & Vento
    Last Post: 12-05-2008, 11:53 PM
  3. Wiring diagram?
    By 82cab in forum Mk2 Golf & Jetta
    Last Post: 16-12-2005, 05:45 PM
  4. Wiring for early GTI system
    By Golf Loon in forum Mk1 Golf
    Last Post: 03-12-2005, 01:23 AM
  5. Golf 1 Headlight Wiring Modification
    By syncro in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 31-07-2005, 10:50 PM
