Originally Posted by
jaffa
I did this changeover at the weekend. Its a bit different to the instructions on the link however.
The main difference is that the Mk3 motor I got has a plastic backing plate, so the backing plates cannot be swapped as in the article. Its even simpler though, just use the Mk3 motor as is. You might need to make a little bracket to support the motor, as the Mk3 motor doesn't have one, otherwise it would bounce around a bit I reckon. Wiring is easy as long as you have a bit of the Mk3 wiring. The wire colours match the Mk 1 loom perfectly.
Speed is better, about 2 seconds a sweep on low speed with the lights on, compared to about 5 before. That might improve if I lube the balljoints, but it seems OK to me, though not as fast as the new Toyota I was following this morning.
