Results 1 to 10 of 10
Thread: Windscreen Washer Pump - Mk I Cabrio
    Jun 2009
    Manly Qld
    Hey guys,
    Bought a new washer pump for front windscreen from the states as old one not working.
    Installed it this morning and still nothing happening!
    Where do I go next? What's wrong with the damn thing???
    Any help most welcome.
    Jun 2007
    Eastern Suburbs Melbourne
    i'm guessing you've checked the lines for holes.
    wire up the pump straight to the battery, to test it's working, that eliminate the pump being faulty, then you'll probably have to start testing the switch etc
    i like volkswagens
    Gosford Central Coast NSW
    hey mate,
    you need to go to supercheap or dcik smith and buy yourself a multimeter.
    come back when you have one.
    if you already have one, check the voltage between the supply wire and ground wire for the pump while someone holds the switch in the on position for you inside the car... then check fuses, continuity between different points in the wire (check for breakages).
    could be a zillion things mate.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2009
    Manly Qld
    hey mate,
    Hey mate,
    Got a multimeter and there is definitely power to the pump. I can only assume it would be the fuse...any idea which one sorts out the washer pump??!
    Perth. WA
    Sounds like your ready to buy a manual next....
    http://www.bentleypublishers.com/vw/...ir-Manual.html
    well worth the money if your going to do your own maintenance..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Quote Originally Posted by gordymatt View Post
    Hey mate,
    if you have power there, then the fuse is OK (power goes throught the fuse first (thats what the fuse is for).
    that means you must have an earth problem. try replacing the earth wire for the pump
    '99 A4 Quattro 1.8T
    As Jarred said, test the new pump first. If power line is ok then test the ground wire. There aren't too many combination here.
    My Mk1 windscreen washer doesn't work either, I just can't be bother
    Jun 2009
    Manly Qld
    Quote Originally Posted by RedMk2Gti View Post
    Cheers for Info...I will carry out the tests tonight.
    Thanks a lot.
    Sep 2008
    Mornington Peninsula
    Question
    Hey guys,
    I've got the same problem, intermittend washer & wiper not working, there is a reley on the fusebox for this. I've ordered a new one at Barlow's (cost $92.00). Hope that will fix it. Run the pump strait from the battery, ok, with the pump diconnected, intermittend wiper works, with pump connected both dead. With pump diconnected, voltage at pump cable 11.8.
    Dec 2007
    Somewhere in Melbourne, Victoria
    Hey guys,
    Mate had the steering wheel off my cabrio over the weekend (a bitch to drive, but fun nonetheless), and found my washer wasn't always working, issue here was the little copper tab that engages or closes the circuit was out of kilter. I bent it ever so slightly (about 1mm) and hey presto washer works a treat. Wish I had taken a snapshot!
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
