i use a needle to clean mine and adjust them
and just thort .... fill a used sharps syringe with turps and inject it in the unit to dissolve anythin in there. Chemist will sell one for $1
Have had ants block it up at times.
Thank you Pete, that's what I wanted to hear.I knew someone would know.
'76 Mk1 Golf - Gone!
'05 Mk5 2.0 FSI Sportline
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
Cheers for the tip. Sounds like a good idea to disolve any nasties stuck in there, but not sure about using a used syringe.
The blockage in mine is mostly from one or more pins that broke off while trying to adjust/unblock it before. It was hard to move so the pin broke rather than the nozzle moving. Why can't these things ever be simple?!!![]()
I'll get to this in the next few days so hopefully I can remove it and it'll work. Cars this old can die a death from a thousand cuts - lots of little things going wrong adding up to too much to fix - so I want to get onto it.
If its got broken pins in it you may want a replacement...
Get Ben to mail one over, but make sure you specify express Airmail.
http://cgi.ebay.com/ebaymotors/Gen-V...Q5fAccessories
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Hey thanks for that. Yep, pins might be a prick to get out (no pun intended). Don't s'pose you'd know if the one on ebay suits Australian made golfs?
It includes a seal between the jet and the bonnet which I'm not sure mine has. Will check tomorrow.
Anyone know if this part varies from Australian made/'76/LS golfs to German made/later/GLS golfs or if they're compatible??
I've ordered stuff from there before, and yes, it can take a while.
