Just make sure if you use a sealant of any sort it is a neutral cure as some sealants can corrode metal.
Also if the seal is replaced the amount of sealant needed should be minimal. I had the Mk1 93cab in the shop a few months ago to put in a new windscreen and apparently the guy either used so little sealant it's not visible or didn't use it at all.
Good luck
1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
