if i were you i'd forget 8" wide rims - it'll be just way too impractical.... thing is... like jarred said, coilovers will give you less room on the front (maybe a little more on the back ~5mm) and this means you'll be doing things like setting your camber to something less than desirable on the front, having little suspesnion travel before you hit guards etc.
for a practically driveable vehicle, 7" will work. offset of no more than ET30 will allow you some camber adjustment on the front so you can still run some neg if you want, and if you roll the guards you'll have no probs with clearance.
you could probably get away with wider on the back in a practical situation, but its impractical to have wheels you cant rotate front to back....
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
