Results 31 to 35 of 35
Thread: Widened Steel Rim Offsets
  1. #31
    Aug 2009
    Just rotate them side to side, and/or flip the tires (inside outwards, assuming they're non-directional).
    I suppose if your current wheels have the same offsets, then the rear hub mounting surface is 10-15mm more inboard than the front, so get 15mm lower offset for the rear wheels.
  2. #32
    Jun 2007
    Eastern Suburbs Melbourne
    If you get different offsets front to back, it's a bit harder to rotate the tyres. just means you have to get them demounted and swapped over.
    rear track is about 8-10mm narrower than the front. sometimes it seems more or less on different cars due to wear, the arches being at different widths etc etc.
    i like volkswagens
  3. #33
    Jan 2010
    Melb Westsideeeee
    Im just a bit curious, on how widening is done and is it possible on any rims?
    I managed to get hold of the BBS from E30 and i wouldnt mind widening them. is that possible and what is the procedure? thanks
  4. #34
    Jun 2007
    Steel wheels are the only wheels that can be widened easily. One peice alloy wheels can also be done (ie it's physically possible) but I think you'd struggle to find a place that would do it.
    Widening steelies is possible my machining out the centre of a steelie and placing the centre into a brand new steel barrel. the other way is banding, which involves cutting the wheel in half and adding in a section, but I dont think many places in OZ do this. not as safe or something.
    or buy some 3 piece wheels and start playing with new lips and bigger barrels etc etc
    i like volkswagens
  5. #35
    Mar 2009
    Empire Bay NSW
    Quote Originally Posted by captainvw View Post
    One of my mates down in Melbourne got his Early Vw rims widened think they where around 150 a rim that was with new outers (7'' wide x 15)
    I can ask him who he used if you like
    Here you go my mates down south have had a few sets done,one of them is currently having 14'' centres put into 15 x6 and 15x5 chrome rims
    http://www.easternwheelworks.com.au/
