have you tried swapping that link end for end? ie putting it in the other way around?
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
What about the L shaped lever on the box itself?
See how the longer arm points backwards and the shorter arm points sideways?
7? MK1 Caddy
12 Amarok
On the grey box, i think you have to grind the sides, (where it stops to get into reverse) so that you can get 1st and 2nd easier. And for 2nd and4th just try using your old linkages, as yours a little to short, also isnt the one in your pic (the one you're touching) ment to be bent?
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Got Stu to have a look today as hes done it before and we tryed a few different things but there seems to be no way around it, i need the taller selector shaft.
MK1 GLS 3door
A4 B7 2.0T
