Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Whos done 4 to 5 speed?
    Boronia VIC
    have you tried swapping that link end for end? ie putting it in the other way around?
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Feb 2007
    LOL, ey i may be from the northern suburbs but im not retarted.
    MK1 GLS 3door
    A4 B7 2.0T
    Boronia VIC
    What about the L shaped lever on the box itself?
    See how the longer arm points backwards and the shorter arm points sideways?
    7? MK1 Caddy
    12 Amarok
    Jan 2010
    Melb Westsideeeee
    On the grey box, i think you have to grind the sides, (where it stops to get into reverse) so that you can get 1st and 2nd easier. And for 2nd and4th just try using your old linkages, as yours a little to short, also isnt the one in your pic (the one you're touching) ment to be bent?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Feb 2007
    Ill have a look tomorrow but i dont remember one being longer than the other.
    MK1 GLS 3door
    A4 B7 2.0T
    Feb 2007
    Got Stu to have a look today as hes done it before and we tryed a few different things but there seems to be no way around it, i need the taller selector shaft.
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2010
    Melb Westsideeeee
    Quote Originally Posted by Spyda View Post
    If im correct, that will give you a closer ratio and that will allow you to get 5th within the confined space?
