Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: whomp whomp whomp noise
    Sep 2006
    Australia?
    did you actually check the wheel nuts though????
    Nope I havent had the chance Jarred will do tonight
    Jan 2007
    also bald and/or unbalanced wheels can make that noise as well...
    Feb 2007
    My gf had the same sound coming from the back of her honda accord.
    It was the wheel bearing, it also didnt help that the tyres where at 56psi
    If the bolts where loose it would be more of a BANG BANG BANG sound as the wheel slaps the hub.....i learnt that the hard way in Lesson1: Tighten your wheel bolts. And in Lesson2: i learnt what it feels like to drive a car with 3 bolts missing and the remaining bolt about to come out, like driving on sqaure wheels.
    MK1 GLS 3door
    A4 B7 2.0T
    Jul 2006
    Ok so driving home tonight, sounds more like a knocking than a whomping, bolts are fine, tyres are very old but still have tread.
    Feb 2007
    Quote Originally Posted by cam0x View Post
    Check the bolt that holds the drive shaft on to the hub, the one right in the middle. Do mk1's have that? I know that made a knocking noise on my mk2 when it was loose.
    MK1 GLS 3door
    A4 B7 2.0T
    Jun 2007
    Eastern Suburbs Melbourne
    the big 30 odd mm nut you mean Dado?
    i like volkswagens
    Feb 2007
    Yeah that one, 27mm if i remember correctly.
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2009
    England
    The nuts on mine are 30mm (cost me £7 for the socket!)
    If it's knocking I'm 95% sure it's the CV joint (speaking from experience ). You'll also need spline tool to get the drive shaft off n all, took me 2 - 3 hours to do on the drive.
    Chris
    Sep 2008
    Fitzroy, Melbourne
    Quote Originally Posted by Spyda View Post
    This happened to me as well, ripped the front caliper off!
    I pulled the hand brake on and luckily slid into a parking spot!
    (more ass than class)
    Good test for the wheel bearing is to jack it up, grab the wheel (one hand on each side) and try and wobble it. A good bearing shouldn't move..
    76' 2dr Kjet
