Not really. But I do have access to a parts catalog which helps.
Later rack has 4 mounting points, spreads the load across the body sheetmetal better, plus its still available...
Highly likely the car will see track days and classic rally usage, so there will be a few improvements to the body structure.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
problems...
tried to keep the housing and only replace the innards..
but they are slightly different...
any chance to get innards for early one?
1976 VW Golf LS 4Door 1600cc
Correct and correct Grant!
Well sorry to hear your car is not the best off at the moment, my rack won't even fit as your car is lhd... All the best. It can be done but will take some time and you will need to either cut some brackets off a wreck, or replicate them.
Could possibly swap over the innards from my steering rack....
Sent from my HTC_PN071 using Tapatalk
1976 Mk1 LS 2L ABA K-Jet
