Not too sure, but if you got the rubber mounts and 'u straps', would it be possible to mount the 'later' steering rack?
Since i had an accident.. Steering rack needs to be replaced...
(Steering wont turn well)
And i bought this
STEERING RACK FOR LHD CADDY GOLF MK1 inc CABRIO SCIROCCO JETTA [171419063] - £39.30 : veedubmachine, Volkswagen Audi Seat Skoda Porsche spares and accessories
For my 1976 carby manual..
But it wont fit...
Mine has different brackets..
It doest have rubber mounts
And it has welded mount on its body..
Anyone has any idea please?
1976 VW Golf LS 4Door 1600cc
'90 Mk I Cabriolet 1.8L - My toy... err... Daily driver...- Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
'99 Mk IV Bora V5<-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
'05 Volvo T5 S60 - 2.5L Turbo AWDReplaced with '09 Ford LV Focus Sedan <-- Used by the kids
'07 Eos 2.0 TFSI - Project Eos...
There's not much available for the early racks unfortunately.
They're far more common here than in other countries and we only had them for 1 or 2 years.
I'd be looking into if you could
1. Swap the innards of the new rack into the old housing or
2. Cut the brackets off the old one and weld them onto the new one.
otherwise you'll have to track down a second hand one.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Early style rack
New style rack
Hmmm looking at the pics my idea about welding the brackets on isn't going to work. Might work for the passenger side. Driver side you'd have to weld the later bracket onto the firewall.
7? MK1 Caddy
12 Amarok
Later rack the spacing between the pairs of bolts is different, how do I know ? Anton and I are modding his 76 to take the later 4 bolt steering rack. This will leave is old rack available for purchase ( direct fit for your 76 ) if you so desire.
Other technical point to note is to install the rack mount correctly you really need to open up part of the bottom of the RHS front axle frame as the mount is sandwiched between this plate and the floor plate.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
That would explain why you bought a left hand drive rack.
As far as I can tell, the correct steering rack should be 171 419 061 B.
