Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Where to get steering rack?
    Quote Originally Posted by Shadow_Rusty View Post
    As far as I can tell, the correct steering rack should be 171 419 061 B.
    You have way too much time on your hands Mick.
    Aug 2011
    Canberra
    Not really. But I do have access to a parts catalog which helps.
    Perth. WA
    Later rack has 4 mounting points, spreads the load across the body sheetmetal better, plus its still available...
    Highly likely the car will see track days and classic rally usage, so there will be a few improvements to the body structure.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Sep 2011
    coolangatta
    problems...
    tried to keep the housing and only replace the innards..
    but they are slightly different...
    any chance to get innards for early one?
    1976 VW Golf LS 4Door 1600cc
    Mar 2010
    Perth
    Quote Originally Posted by roccodingo View Post
    Correct and correct Grant!
    Well sorry to hear your car is not the best off at the moment, my rack won't even fit as your car is lhd... All the best. It can be done but will take some time and you will need to either cut some brackets off a wreck, or replicate them.
    Could possibly swap over the innards from my steering rack....
    Sent from my HTC_PN071 using Tapatalk
    1976 Mk1 LS 2L ABA K-Jet
