Results 1 to 7 of 7
Thread: Where can I get a refurbished or new Warm Up regulator ?
    I've got a 1990 Mk1 Cabriolet. The warm up regulator is faulty (hunting RPM at idle after engine warms up). It also seems to have gotten a little thirsty
    I've had it pressure checked by reputable VW mechanic & inicated that warm up regulator is faulty - (quite a common fault with the Mk1 cabrio apparently).
    Mechanic priced a new unit at $1000 !!!! But surely there might be soemone out there with a refurbished or aftermarket unit at a more reasonable price. (which is what the mechanic suggested I do)
    I've found a unit that I can get from US - but seems I should exhaust all loal options first.
    I live in Sydney - but don't mind sourcing a regulator from inter state.
    If anybody can help that would be great !
    Quote Originally Posted by FangioVW View Post
    Welcome FangioVW,
    Is your car running k-jet ? I probably have one sitting somewhere.
    Perth. WA
    Thumbs up recon / replace or calibrate.
    Hiya Fangio,
    I would recommend these guy's,
    http://www.aussieweb.com.au/details.aspx?id=1927786
    I sent them my fuel distributor and control pressure regulator for overhaul
    Did a great job, car ran flawlessly when i got them back.
    Was about 8 day turnaround from mailing the parts over to getting them back.
    These guy's can likely do the same ..http://www.southportfuelinjection.co...0Injection.htm
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jun 2007
    Country Victoria
    last year I had a problem with the Cabby not willing to accelerate after starting on warm days. After about 5 minutes, normal service resumes. This problem went away (Fingers crossed) so I no longer worry about it.
    I was told it was the Warm UP Regulator sometimes known as a Control Pressure Regulator, which needed to be replaced as they are not repairable.
    So I am quite interested they can be rebuilt, Whats the cost on that service?
    (If you don't mind me asking)
    Michael
    Camden, Sydney
    Thay are dear as poison.
    I`d get one from Engerland.
    Keep us posted with how you go with it.
    Smile WOW - thanks guys.
    Thanks for the leads.
    To the various posters - Yes its a K-jet with Lambda 1.8 L & yes they are rare & dear as poison ! While widely available in the UK they are around the 250 pound mark meaning that landed in Aust. I'd be looking at around $600. I think the best bet is sourcing one from the US (see below) if I chose to go down that road.
    REDMk2GTI - thanks for your offer - I'll get the part number off the unit see if it matches - I would presume it may need reconditioning ? (I'll work out how to send a private message to you through the forum - looks like I can but haven't tried it)
    The chap at Southport was willing to do an exchange, however, he refered me to a chap in Sydney to check with him first. He has not returned my call yet. Anyway, the chap at Southport said he may not have a unit to exchange - so I'll need to send him mine. This is a big problem as my wife uses the Cabrio as a daily "hack" to go to work - so it would be difficult to "park" the car for a fornight. So, REDMk2GTI - if I buy yours & send that to Southport - that might be a good solution for me even though it might cost me extra.
    To all you others out there - I came across an Ebay listing for a refurbished regulator from the US - it will probably be around the A$300 mark landed in Aust. The seller was " pelhamautoparts " - they seem to have a large selection of VW parts. Unfortunately the regulator was sold before I had a chance to double check the part number. A new one hasn't been listed & I'v sent a message asking if they have more.
    Just click the member name and select 'Send private message............'
    Super easy...
