well, i just check it
and one brush is worn.. about 5mm shorter than the other one
Hi,
I have 1976 golf LS 1600cc carby.
I brought it to korea from aus.
and Now i have problem with the alternator.
the battery light doesnt come on, on ignition 1st stage..
and the battery light come on often on idle..
and I can feel that the power is poor sometimes..
i heard i could be the regulator and the brush pack.
where can I find them?
the regulator says Ingram 831256 made in australia
could anyone help me to get it to korea, please?
1976 VW Golf LS 4Door 1600cc
Repco sell the complete unit or a good auto electrician.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
I have a KAE brand, made in German. Compatible to your Ingram.
Are you in Korea or Australia ?
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
Bump!
Anyone have the correct part number for this?
The picture in the manual shows the borsh part number as 0192 052 004 (which is the same as whats already on mu carby GLS).
However, autboarn/repco cant find anything on this.
The part number 1197 311 028 works, however I'm pretty sure this is for an alternator from the k-jet car (from my mates cabriolet). So unsure if it will fit.
Go to an auto electrician. Any bosch external reg alternator are a plentiful, therefore the regs are always stocked to and the reg will only cost around $30 and 10mins of your time to replace (2 screws, 1 wire).
I used to work at an auto elec rebuilding alternators and starters, they had plenty of them.
You can even just replace the brushes, but for $30 you wouldn't bother.
