Results 11 to 20 of 23
Thread: Wheels and suspension for MK1
    Apr 2006
    Hobart,Tas
    The problem a lot of people forget when "slamming" their Mk1s is that they overlook clearancing the body above the RHS driveshaft. The driveshaft effectively becomes a new bumpstop!!!
    This is one I had in at work last week, hope the owner doesnt mind me showing this pic but it is a warning to others.
    Aug 2006
    Melbourne VIC
    Yeah as Adrew mentioned you must cut and box the lowere section so drive shafts dont bottom out
    Camden, Sydney
    Quote Originally Posted by Water Boy View Post
    Or at the very least whack it with a hammer in the right spot
    Jun 2008
    Hobart, TAS
    Quote Originally Posted by gtimk5 View Post
    the owner doesn't mind
    can't say i really know how to fix it yet tho haha
    either have to cut a piece of the chassis or raise the car a little yeah?
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Apr 2006
    Hobart,Tas
    Can fix very cheaply for you mate. Book it in.
    Hows the overheating? Fixed??
    Andrew
    Jun 2008
    Hobart, TAS
    sounds good, i'll give you a ring 2moro.
    not sure, only drove it back home but the guage was still reading a little high so dunno.. hope so tho
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Jun 2007
    Eastern Suburbs Melbourne
    I've seen that section boxed a couple times.
    The method i would use if I had to [or may have to soon ] is to get some round MS pipe. roughly 2-2.5" dia.
    cut the section from the rail, and use a half section of the pipe to join up the sections of the rail.
    It's hard to describe without pics, but I hope this give a rough idea. I've never done it personally, but I like the theory
    i like volkswagens
    Jan 2009
    south west sydney
    sorry to hijack but... what are the other options for achieving the lowest legal ride height without coilovers, custom springs and shocks? the attractiveness of coilovers for me is the height adjustment but really i'd just want to be low n slow not a high performing suspension setup.
    what suspension are you running SpeciP3?
    Quote Originally Posted by micheh2000 View Post
    mate, you can get cheap coilovers for about as much as it would cost for shocks and springs and you can have it whatever height you want! all for about $800
    Jun 2007
    hottuning aren't what I'd regard as a 'high-performance' suspension set up. [ie not a track based suspension] it' is, imo atleast, a street based setup.
    They give you upto 120mm of drop, which is about as much as most people want, [in fact heaps more than most people want] & are a stupidly easy option. More expensive would be a air bag setup. Around 8-10K for a custom setup, but you'll be able to park it on the deck.
    all depends on what you want. The hottuning coils are a goood start I reckon. Hope this helps.
    i like volkswagens
