Results 1 to 10 of 11
Thread: wheel bearings
    wheel bearings
    took my golf for a bit of a drive today which was sweat didnt push it got to 60km/h at 3750rpm in second.. but u could feel the shaking in the wheels i know now what the problem is. the left wheel bearing is shot and will be my first purschase when i get some more money tommorow
    imported_brackie Guest
    Front wheel bearings
    Hve you done the job before? You really need a press. Don't buy them from a dealer as there are plenty of places who sell equivalents.
    a press??? ****... might havta take it down to volkspower get them to do the whole lot for me more money
    You could take just the bits you need to down the shop to get pressed and do 95% of the work youself, it's easy. Save the money for angel eye's or somethink. Think simple, the only way to go, don't get flusted by the job, just take you time if youv'e got the time that is, And u will wonder what all the fuss was about.
    Good luck !
    Dave
    _____________________
    :twisted: MK1 THE BEST :twisted:
    :arrow: 16V OF COURSE
    Don't panic!
    Wheel bearings aren't that hard to do. Most automotive workshops have a press and lots of guys will press them in and out for a few $$$s (Nice guys for $0)
    Don't panic
    That's what i was going to say brackie, was late last night almost drifting off.
    Yep the nice guys will charge $0, some guys will try and sting you if they see your not to sure what you want done.
    You will also need to buy some grease as well, one of those small tubs from super cheap, couple of clean rags, jack, jill and definatly need a 30mm socket and a braker bar with some pipe to lever it.
    Or a good rattlegun !
    You should go and buy socket as you will need to change bearings in future, and will be money well spent get a good quality one as you want it to last because you'll be putting considerable pressure on it.
    Good luck
    Dave
    ________________________
    :arrow: 16v MK1 even better
    thanks guys for all this help. ill take off the wheel bearing and buy and new one and get it pressed.. ill get back to you on the updates
    syncro Guest
    Make sure that you tighten it up with a tension wrench or they won't last long. They need to be tight!
    Quote Originally Posted by syncro
    good call... just like your wheels you dont tighten and your wheels will fall off
    I've done wheel bearings in the past too, and it's quite straightforward:
    Slacken the centre nut before anything else - you may need to have someone in the car with their foot on the brake. I used a bit of water pipe 2m long on the end of my socket handle and still had to bounce on it! A wheel puller over the end of the socket and hooked through the slots in the wheels stops the socket comming off the nut.
    Mark your camber bolts and take the wheel housing off by removing the camber bolts, tie rod end and lower ball joint, and hang the brake caliper out of the way. That way you can go to a place with a press with just the wheel housing and new bearing. Once you've pushed the old bearing out grind a little off the perimeter and use it to push the new bearing in. Return to car and re-assemble! Check the centre nut torque after driving a little.
    Cheers...PG
Similar Threads
  1. Wheel bearings & control arm bushing
    By MattyT in forum Mk3 Golf & Vento
    Last Post: 27-02-2007, 11:18 PM
  2. mk3 - wheel alignment done myself
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 10-01-2007, 09:00 AM
  3. Hollow MKV Rims from BBS
    By mikinoz in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 29-05-2006, 06:47 AM
  4. Set wheel alignment for free
    By imported_brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 13-05-2006, 01:47 AM
