Wheel bearings gives a droan or a hum and gets worse when you load up the wheel in question. Squeeks can also happen in the straight line if there is play. You mention you have play at the hub in question. First check the tension of the hub nut mate if you have just done CVs. If this is at least 190NM then the bearing is tata
Cheers and good luck
JMac
