Results 1 to 7 of 7
Thread: What size Battery you mach 1 guys running?
    Mar 2009
    Empire Bay NSW
    Going to replace my battery in the Mach1 has a weber without a choke so i need it to be ready and willing for those cold winter mornings currently has a N52 but its seems fairly big for the size eng etc wondering what you guys are running
    thanks L.J.
    Jun 2007
    Eastern Suburbs Melbourne
    I went with the bigger is better principle.
    I think I had a 550CCA battery in my 2 door and then in the diesel as welll, never had issue with it. I think a good strong battery is key with old golfs, helped a few niggles with my 76er at the time. Had it dead flat and overcharged and everything, but still worked a treat. I think it was a champion.
    i like volkswagens
    Feb 2007
    The main issue you should be worried about is if the car is going to be sitting around for a while.
    A normal sized battery is fine, you should be able to start the car a bunch of times in a row with a normal, healthy battery. If you cant then your battery isnt healthy.
    Im running an optima yellow top because of the sterio, but before that i had a regular 'small car' battery and a mk1 that needed 4 goes to start and the battery was fine.
    MK1 GLS 3door
    A4 B7 2.0T
    Jun 2008
    Hobart, TAS
    Had a 550CCA maintenance free battery in my mk1 also. great battery, no dramas and no acid leak issues either
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    May 2009
    Please Enter Location
    if your in oz get a century battery din55 its what i run here in nz and what i sell so i know there good!!
    Nov 2005
    its pronounced "mk1" or "mark1"
    dom
    I've always ran for as long as I can remember a BMW E36 compact (316i) battery.
    50aH
    450 CCA.
    They are a nice & small fit & I think over the period of 14+ years, I've only ever had to replace it once & that was from being damaged in a crash!
    So although it maybe around the $200 mark, its money well spent for it to last as long as they do.
    I also run one of these on my mums Mk2.
