Thierry and Peter are both right.
In the UK if modifying a Mk1 GTI that already runs kjet, a 16v is relatively easy, as parts are cheap and easy to come by and the car and the engine run the same injection system.
There are bugger all 16v VWs in Australia, so all parts are harder and more expensive to get and kjet is misunderstood and parts are expensive.
There are more and more 20VT cars being wrecked here and so these engines are more plentiful. The ecu and turbo piping and wiring will still cost you, but the car will be quicker and more reliable at the end of it.
It will still cost you $5k - 8k minimum to get a 20VT in your car running.
The budget option is the 2L EFI from a Golf 3, which is cheap and easy. The motor, gearbox and loom will cost you about $1500, which is
Engine $400
Gearbox $700
Factory Loom and ecu $400 or so, or go aftermarket.
Or find a whole smashed Golf 3
Whichever way you go with a late model engine, you will need to do some wiring work to the Golf 1 and probably change the dash to fit in a later cluster.
With my Mk1 Caddy, I have a 2E 2L EFI engine with early 8v GTI 5 speed gearbox, Factory wiring and uncoded ecu. I used the later fusebox from the golf 3 and used the whole loom rom the Golf 3 and just spliced in the Mk1 taillights. I used a Mk2 dash, into which the Mk3 cluster fits. That means you turn the key and the motor thinks its a Mk3, so you get reliaility and the car is light like a Mk1 so you go fast.
If you dont like wiring, get a 1.8L with a big cam and a dirty great webber.
