Results 1 to 10 of 17
Thread: What to look for when buying a Mk1?
    I'm about to be in the market to buy a Mk1 golf (I'm trying to sell some personalised number plates). I'm looking for a 3 door model and I originally wanted a GTI but I can't afford it =/
    In your experience, what should I keep an eye out for when looking at a Mk1?
    I want this as a project/weekend car and I'll probably give it the 'rat' look. I know some people don't like it, but I LOVE it
    Any help would be greatly appreciated.
    well the most common thing on a mk1 is rust.
    the rust is most likely to be found around the pillars area and the floor of the car.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
    Jun 2007
    Eastern Suburbs Melbourne
    depends what your strengths and abilities are when it comes to working on a car.
    if you have access to a welder and can weld, alot of rust you'll be able to fix, so it broadens the range of potential cars. There's also sometimes a few electrical issues as mk1's are getting old now.
    it's best to start off with the cleanest car you can find and or afford. Pretty much everything mechanical can be replaced or upgraded, but I foudn (when I bought my first car) it was better to have something that was running and close to Roadworthy, and go from there. 2 doors are sometimes harder to find and slightly more expensive (more desirable for some) but parts shouldn't be any harder to come by than 4 door parts.
    Rust will be the major issue though. the structural (and body) areas are: around the windscreen and (complete) A pillars, floors (mainly the front footwells and spare tyre well/boot area), under the radiator, rain tray, lower sills (complete).Check the wheel arches too, they can be prone to rust in thier extremities, also the join between the roof and the C pillar, as well as the roof gutters/sills. Check where the tailgate joins to the roof as well.
    body panels: Front fenders lower qtr behind the wheel, doors- both lower corners and bottom edge as well as under the window trim. Tailgate - both bottom corners, and under the window as well.
    So basically, they can rust in a lot of places. If you found a car with about 3 or more major rust issues, in structural/body areas, I'd keep looking personally, (unless you can weld or have acess to someone who can etc) removable panels with rust are much less concerning, as they can be replaced with relative ease. Most mk1's are bound to have some front window/A pillar rust, as well as surface rust around at a few of the other structural areas. bolt on panels are likely to have some rust too.
    I'm not trying to scare you away from getting a mk1, I think they're great and love em too bits, just trying to be honest and helpful!
    i like volkswagens
    Big thanks for the helps guys. To be honest, I've never really done any major work to cars before. My brother is pretty good with cars and bikes. My grandpa has some welding gear and he could maybe get any rust out.
    What about engine wise? Anything I should look for there?
    Jan 2009
    Sydney, New South Wales
    Motors are pretty good, just be aware if they are original as they are getting on in age. The carby's are the most annoying I'd say with the auto choke. You'll mostly likely get a 1.6 as they were the most common type sold in aus.
    Quote Originally Posted by DangerDan View Post
    the engine choices that bolt straight into the mk1 are vast and relatively cheap, so I'd most likely be concentrating on a straight and relatively rust free body before worrying about a dead 1.6 banga, people give the dam things away!
    good luck!
    Hmm, I've heard somethign about this auto choke. I'll have to do some research about it. I'm really keen to buy one and it's so hard not to just jump in!
    Jun 2007
    yea the stock carbs are getting old, and with age comes problems. plenty of easy upgrade, both carb and engine wise available though.
    i like volkswagens
    Yeah I've seen a few engines and parts available for sale throught his website. Should come in very handy.
    Can anyone quickly explain what this auto choke is?
    DangerDan, I was kinda looking at your Mk1 for sale
    Jan 2009
    yeh i've pulled the carpet up and there's little rust (nothing a grinder cant fix) and driving to gerringong the other day, i drove from georges hall sydney. Thats was 120Km each way at 100kph (P plates) for 2+ hours straight, no stopping. And she drove like a dream (apart from the vibration of the accelerator pedal). I even stormed past cars comfortably at 120+ (FUN!). And all on one tank of $30 worth of premium. Cant ask much more of a 33 year old car. They dont look bad either. Wish i could have drove down in the mk2 but shes been towed up to matts (hope he'll fix her).
