Results 1 to 8 of 8
Thread: What happens When....
    Sep 2009
    Chillaxing in Tas
    A outer CV joints decides it hates life and explodes all over the road?
    Curious to know as i got a CV joint that clicks now and then, and i plan on lowering the car which from what ive read can be harder on the joints. What actually happens when one lets go? is the car still able to limp home, or will the shaft just openly spin due to the open centre diff?
    Feel free to add more "What Happens When" questions
    <space for rent>
    Feb 2006
    Perth Western Australia
    if it actually lets go and the bearings come out then you will be on the side of the road!!!!!!!
    I've broken a couple of the balls racing but never all of them, either way better to do it sooner than later
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by Volksee77 View Post
    ahha cheers, i got replacements so its ok, was curious to know how nasty the "blow out" is.
    Dont want to lock up on the hwy for example.
    <space for rent>
    Aug 2009
    Good excuse to weld the diff too? Then if one blows at least you might get home.
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by Jace View Post
    So ghetto, ill leave that to the VL and Rolla blokes
    <space for rent>
    Aug 2009
    ACT
    Perfect for a FWD haha
    Jun 2008
    Hobart, TAS
    Had this happen in my mk3 yesterday, pin came out of the box and punched a hole in the bell housing. To answer your question yeah it'll still move but not easily and you may need a neck brace when you're done
    Feb 2010
    Perth
    Only know from four wheeling experience, but, generally when you shatter one, it's a no drive affair, steering is adversely effected as the chipping and gunk builds up and eventually you kill the housings...
    Beauty of 4wd in a way, you can still get home!
    77' MkI Golf GLS - VR6-T Project Compression
    79' MkI Golf GLS - 2L ABF ITB's Wolf3D
    09' MkV Golf R32 - sold
