Page 94 of 99 FirstFirst ... 44849293949596 ... LastLast
Results 931 to 940 of 981
Thread: What did you fix/replace on your Mk1 today?
  1. #931
    Aug 2011
    Canberra
    Hmmm, found the souce of my 'roughness' when hitting a 15mm step in the road...
    Turns out that the car is sitting 10mm off the front bump stops without me in it...
    If I sit on the front quater panel, it bottoms out...
    Now to figure out how to fix it...
    First I'll need to check driveshaft to chassis clearance, as the car doesn't appear to sit too low.
    Then I'll probably trim the bump stop to give more clearance, but still not allow the driveshaft to hit the chassis...
    But I'm definately open to suggestions...
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  2. #932
    Oct 2013
    Forest Lake Queensland
    Spent a few hours wasted time trying to fix Cabriolet electric roof,Aerial and electric windows to no avail.
  3. #933
    Aug 2011
    Canberra
    I looked into my electric roof issues, and found that my hydrolic pump was completely missing...
    Interestingly, according to the manual, the key needs to be in the ignition in the off position for the electric roof to work.
    Doesn't work that way on mine, as the relay's click regardless of the key / ignition, but it may help with your troubleshooting...
  4. #934
    Aug 2011
    Canberra
    Hmmm, had a weird noise coming from my rear right wheel on the weekend...
    Decided not to risk it, and took it off.
    Found that the stub axle nut had loosened by 3 turns, and that the noise was a loose spring in the drum...
    The nut retainer was too short to actually stop the nut spinning till it had undone a little.
    Put an extra washer under the nut to space it back into the retainer properly, and all good...
    Also, figured out found that the last guy to work on this drum must have really not cared...
    Both of the pins / springs / retainers that hold the pads to the backing plate are completely missing.
  5. #935
    Isn't it time you started your own thread Michael?
    Hope you didn't get too wet leaving the racing on Friday night.
    Paul
  6. #936
    Aug 2011
    Canberra
    I did have a thread over on the CBRVWOC forum, but it seems to have gone offline...
    I really should start another...
    Thankfully the roof really only leaks with standing water, and even then, it runs down the inner roof to either side of the car...\
    Still, I really should get it fixed... I hate having to put a tarp on the roof when I know it's going to rain...
    Paul, I've been meaning to ask you for a while, do you happen to still have any Mk1 bits lying arround?
    Thanks
    Michael
  7. #937
    I've got nothing left. Track down Nick from VolksSpares - he's still got over 50 MK1's in his yard at Bungendore. All slowly rusting away.......
  8. #938
    Jan 2006
    Did a whole heap of little things today and yesterday. Cleaned up heaps of wiring. Got rid of the ABF idle stabiliser valve completely, it works really crap with the haltech. Instead I now have a little solenoid that opens up an air bypass to bump up the idle slightly whenever the thermal fan kicks in, and I set up a switch on the dash as well to bump it up for cold starts during winter, or whenever I might want a faster idle. Much simpler, and a lot cleaner in the engine bay too.
    Style of the idle-up button may be a little incongruous, but who cares:
    The solenoid hidden back where the brake booster is:
    Nothing but a shiny alloy bung where the ISV and associated plumbing used to be:
    Scratched away at a small rust spot on the passenger side floor, I'm going to have to cut a little piece out way up in the front corner (water was leaking where the antenna cable goes through the wheel well). Treated it so it doesn't get any worse and will start on that soon. I'm probably going to have to rip up the entire floor sealant to ensure everything is ok, really not looking forward to that job.
    Next up, a big brake refresh, new braided lines all round and new slotted rotors. Hopefully that will yield results when the supersprint rolls around in May..
  9. #939
    Aug 2011
    Canberra
    I was about to kick it, when it fixed itself...
    lol.
    Really though, I wouldn't have kicked it, no matter how much it deserved it.
  10. #940
    Italy, Piemonte
    Just picked up the Cabby from the body shop for some little touch-ups...
    Getting ready for those 15" rims...
    Attached Thumbnails Attached Thumbnails What did you fix/replace on your Mk1 today?-xkmr-jpg
