What happened? Positive camber?! OH NOES!
Good ol' Hotwires hey. They're alloy aren't they? Needs polished lip!
Looks great.
Oh Noes!!!
What has happened
<space for rent>
Looks great.
Hahha, nah no + camber, its just the weird angle the phone took
And yeah, hotwires...
<space for rent>
Had to remove rear sway bar. Didn't realise when I lowered it that the sway bar was hard against the diesel inlet pipe (where u fill it)and cracked it. Only realized when car was parked on an angle and it left a big puddle of diesel.
adjusted exhaust again as it moves after a week or so... need a flange instead of a clamp...
Also fitted my Hood Lifts.. works a treat Just need to oil them up or just open bonnet 100+ times lol
<space for rent>
hey guys, i have just had a bit of work done with the golf..
ignition wiring setup fixed, timing was WAY out, fixed brakes..
bottom line is.... the car i bought in march that was sitting on flat tyres in long grass.. is now running on 15's and ready to get sorted with rego
2012 Ford Focus - Panther Black
Previous - 1977 VW Golf GLS - 2E (beige beast)
Previous - 1976 VW Golf Ls (flipper blue)
Good to hear of progress Josh. I'll assume it's mythical though because I'm not seeing any pictures...
From my car's thread:
Tested it. It works.Fixed the odometer today.
Removed Bezel
Speedo out...
...exposing this little bastard on the right hand side (the odometer drive cog)
I drilled out the center of the cog the tiniest little bit and glued it back on.
(it's because it's pressed on from factory that it cracks)
Reassembled and cleaned
All done.
Needless to say, I cleaned absolutely everything I could as I went along.
didn't technically 'fix' anything, but I cleaned out the interior today. Carpet is pretty shonky, might have to look up a new one. Also discovered an exhaust leak, luckily in the rear part of the system.
on the plus side, my interior is alot cleaner and I made $7.20.
Nothing beats making money back from the PO.
Cash back guarantee!
cut the second tailpipe off, re-welded it having welded a bit of metal pipe over the hole from the main shaft (so it's now a dummy pipe). cleaned the chrome tips and put them on. bled all four brakes, and went for a quick blat around the block
more details and pics at Car Blog | So close now... - JUST Cars if the link happens to work...
There is no Golf in my life. This is unacceptable...
