Page 68 of 99 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 981
Thread: What did you fix/replace on your Mk1 today?
  1. #671
    Sep 2009
    Chillaxing in Tas
    Oh Noes!!!
    What has happened
    <space for rent>
  2. #672
    Aug 2009
    What happened? Positive camber?! OH NOES!
    Good ol' Hotwires hey. They're alloy aren't they? Needs polished lip!
    Looks great.
  3. #673
    Sep 2009
    Chillaxing in Tas
    Hahha, nah no + camber, its just the weird angle the phone took
    And yeah, hotwires...
    <space for rent>
  4. #674
    Aug 2009
    Torquay, victoria
    Had to remove rear sway bar. Didn't realise when I lowered it that the sway bar was hard against the diesel inlet pipe (where u fill it)and cracked it. Only realized when car was parked on an angle and it left a big puddle of diesel.
  5. #675
    Sep 2009
    Chillaxing in Tas
    adjusted exhaust again as it moves after a week or so... need a flange instead of a clamp...
    Also fitted my Hood Lifts.. works a treat Just need to oil them up or just open bonnet 100+ times lol
    <space for rent>
  6. #676
    Jan 2010
    Baulkham Hills
    hey guys, i have just had a bit of work done with the golf..
    ignition wiring setup fixed, timing was WAY out, fixed brakes..
    bottom line is.... the car i bought in march that was sitting on flat tyres in long grass.. is now running on 15's and ready to get sorted with rego
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
  7. #677
    Aug 2009
    Good to hear of progress Josh. I'll assume it's mythical though because I'm not seeing any pictures...
    From my car's thread:
    Fixed the odometer today.
    Removed Bezel
    Speedo out...
    ...exposing this little bastard on the right hand side (the odometer drive cog)
    I drilled out the center of the cog the tiniest little bit and glued it back on.
    (it's because it's pressed on from factory that it cracks)
    Reassembled and cleaned
    All done.
    Needless to say, I cleaned absolutely everything I could as I went along.
    Tested it. It works.
  8. #678
    Jun 2007
    Eastern Suburbs Melbourne
    didn't technically 'fix' anything, but I cleaned out the interior today. Carpet is pretty shonky, might have to look up a new one. Also discovered an exhaust leak, luckily in the rear part of the system.
    on the plus side, my interior is alot cleaner and I made $7.20.
    i like volkswagens
  9. #679
    Aug 2009
    Nothing beats making money back from the PO.
    Cash back guarantee!
  10. #680
    Nov 2009
    NZ
    cut the second tailpipe off, re-welded it having welded a bit of metal pipe over the hole from the main shaft (so it's now a dummy pipe). cleaned the chrome tips and put them on. bled all four brakes, and went for a quick blat around the block
    more details and pics at Car Blog | So close now... - JUST Cars if the link happens to work...
    There is no Golf in my life. This is unacceptable...
