Page 66 of 99 FirstFirst ... 1656646566676876 ... LastLast
Results 651 to 660 of 981
Thread: What did you fix/replace on your Mk1 today?
  1. #651
    Boronia VIC
    Found a failed Expansion Tank cap.
    The pressure relief valve had come apart inside the cap.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #652
    Jul 2005
    Newcastle, NSW
    Nice work Mik. Is that with the New ecu?? Sounds like both the sensors are the wrong one.
    Same ECU as you had, but Beau had some sort of special soldering job going on. I hacked it back a bit and then did it as per the bentley, improved things a bit.
    After testing it seems I am not getting enough advance, need to check it again in the am, and there is a resistance problem with the idle/wot switch (where can you buy them new?).
    Fun, fun, fun.
  3. #653
    Aug 2009
    Touched the car for the first time in ages today.
    Found two vacuum lines were disconnected, popped them back in, with no real difference.
    Do all those multi-coloured lines really need to be there?
    Gave the car a run. Did a burnout. Was fun.
    Might (read: 'probably won't') go to a brake joint through the week and see what they can do for replacement rotors and pads. Discs on my car are about 8mm thick.
    So I didn't really fix/replace anything. Story of my life.
  4. #654
    Nov 2009
    NZ
    Dismantled...
    The sunroof mechanism: removed it all and gave everything a good clean. The trim is currently being stuck back on to the inner lining thingy. That'll be done by next weekend then the whole shooting match can go back in. Hopefully i'll then have a tilt and slide roof as opposed to just a slightly tilty one.
    The exhaust: took the back box off in readiness for re-welding of the second (dummy) tailpipe, which will hopefully cure some of the excess noise.
    The horn: found one of the wires was loose so dismantled the steering wheel, put new clamps on the wires and replaced the double sided tape on the inside of the wheel centre.
    The engine: tweaked the idle speed. Nearer 1000rpm than 600 now. Much better.
    Weight reduction: removed the amp and a pair of 6x9s from the boot, taking off around 10kgs I reckon. Rear strut brace will go back in once I can find some nice rubber rings to cushion it a bit.
    Next weekend: putting it all back together and booking the roadworthy for first weekend in July
    There is no Golf in my life. This is unacceptable...
  5. #655
    Jan 2008
    Surrey Hills, Melbourne
    Got mine serviced last week, but it still idles too high when cold and warming up (up to 1500 rpm).
    Had an exhausting time yesterday when I removed old parking permits and put on a brand new pink (eek) one. Just too much
    Actually, I washed it and noticed some serious rust on the bottom of the passenger door. Haven't had a close look but it's about 20-30cms long and has gone through the outer skin on the bottom . Dang.
    So I fixed/replaced nothing. But I do have to re-glue the vent window (again) - the wind going through the gap is annoying.
    '76 Mk1 Golf - Gone!
    '05 Mk5 2.0 FSI Sportline
  6. #656
    Jun 2007
    Eastern Suburbs Melbourne
    get some deoderised fish oil onto that rust pronto
    help slow it down some, as well as cleaning the inside of the door so there is less crap there
    i like volkswagens
  7. #657
    Aug 2009
    Jarred, have you found any deodorized fish oil that actually doesn't smell like fish?!
  8. #658
    Jun 2007
    there's one I got from supercheap that wasn't too bad. within a day or two you couldn't even smell the it, and when you sprayed it, it hardly smelt that bad anyways.
    I think it was a septone product.
    i like volkswagens
  9. #659
    Aug 2009
    Septone products are usually pretty good. I think my fish oil is Export, might as well rub rotting fish all over rust in my case!
  10. #660
    Jan 2008
    So would fish oil be best at this stage or rust killer first?
    I used some fish oil that doesn't smell too bad. Not overpowering but you wouldn't want to spray it on before a night out. I think it's Export, not sure. Don't mind the smell if it does what it's supposed to.
    Actually my parents take heaps of those enourmous fish oil capsules - maybe I should just used some of them. Fish oil - the miracle product.
