wow what wheels are they more pics!?what coilovers did you use?
fixed my handbrake, driver seat belt, and re glued quarter window hinges
install coilovers and new wheels tyres.still need to adjust the height after installing arches.need to look into getting rear disk brakes set up and i bit consern how does converting from drums to disk may change wheel clearance etc.
76 Scirocco
wheels are Manaray sport reverse gear MJ9 16x7.5-8.5 et33 195/40 tyres. JOM coilovers.my drum brakes are gone from little noisy to extreme.trying to figure out why???
did you check your bearings? they could be on thier way out/too dry. easy to replace, not expensive either.
Put a notch in the subframe/stress bar so that the dump pipe won't hit anymore, made up a bracket to support the turbo which will hopefully prevent the turbo studs from stretching/nuts coming loose and then blowing out the gasket. Very slowly ticking things off the May supersprint todo list. Have to figure out how to fix the fuel surge issue - damn internal line in the fuel tank has rotted away.
turbo? what? when where?
details?
Come to the supersprint for the Nats Jarred and you will see it![]()
Replaced one front guard with a rust free one, pity its blue and car is green
doing other one tomorrow.
bout time i did, bottoms of green ones where falling apart, and they where rather beat up.
Also put the Last tinted window in (yes im lazy)
Adjusted clutch cable again, think i got it now.
Paid for Carby monday, if im lucky ill have it friday, if not next week. then she will be running again.
<space for rent>
Cleaned and re-oiled my air filter from all the filth that had stuck to the old oil in the filter. A slight performance difference was definately noticable!
Rear wheel bearing rginding and whining big time, anyway put a new one in, the old one just fell apart when I finally got it off the centre shaft.
1993 MK1 CAB ! Work in Progress........
