Page 95 of 99 FirstFirst ... 45859394959697 ... LastLast
Results 941 to 950 of 981
Thread: What did you fix/replace on your Mk1 today?
  1. #941
    Aug 2011
    Canberra
    That's one very nice Cabby... and, it's going to look even better with those really nice wheels...
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  2. #942
    Italy, Piemonte
    Thank you very much...!
  3. #943
    Dec 2010
    White walls!
    What did you fix/replace on your Mk1 today?-imag3324-jpg
  4. #944
    Aug 2011
    Canberra
    Fixed my lefthand wiper today...
    Driving along in torential rain (well for Canberra anyway), the left wiper decided it wanted to be on the righthand side...
    Thankfully it missed the other wiper and then just sat at the bottom of the windscreen...
    Not the most fun rest of the trip... Used the wipers as little as possible so as to not strip out the splines anymore than needed...
    Once at work, I grabbed a pair of pliers from my desk, and then tightened the nut...
    All good now...
    Try doing that on a newer car... lol.
  5. #945
    Aug 2011
    Canberra
    Put the roof up this morning, and ripped the roof securing handle clean off...
    Now to find a replacement...
  6. #946
    Jun 2012
    Adelaide, South Australia
    smashed the prep work this week (sanding and making the doors dead straight), and by the time I'm done tomorrow the whole car should be very close to being ready for primer. Most panels are already quickly coated in Hi-fill primer
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  7. #947
    Jan 2006
    I have been noticing a creaking sound when turning at low speeds. I got my wife to move the steering wheel left and right while I checked the rack, turns out as I suspected there was some movement in the drivers side bracket.
    Pulled things apart and I found 2 hairline cracks down underneath where the bracket is spot welded to the underside. So time to reinforce the sucker. I mainly seam welded all the various joins, but I also added a couple of extra pieces in for bracing. Should be right now! I already had a piece of flat bar joining both brackets (you can see the underside of it in the pics) and this still happened. I'd recommend checking your mk1's so you catch this before the cracks get nasty, or worse still the bracket comes right off.
  8. #948
    Jun 2007
    Eastern Suburbs Melbourne
    Had a cracked bracket on my mk 1 cabby when I first bought it. Apparently a reasonably common issue caused by the larger (185/195 tyres) being turned alot at low speed. SO I wouldn't be surprised that any mk 1 with some more serious rubber and/or serious usage having this sort of issue.
    i like volkswagens
  9. #949
    Jan 2006
    Yep, the cabrios have more weight too, as does mine with an ABF and heavier box etc, so it makes the load even worse. Also, the real load is almost all on that one bracket, its the side of the rack that limits any sideways movement, the other side is free to move through the bush. Maybe the other bracket is stronger for the original LHD configuration. Anyway, a worthwhile area to check and definitely strengthen if you already have the motor out or at least have the downpipe removed.
  10. #950
    Jun 2007
    yep, 100% right.
    Quite fiddly to do with the dp in, but managable.
    i like volkswagens
