Excuse me while I write some Search lines.
cv joint repair cv boot replacement how to remove Golf mk1 axle
So I am looking under the engine for an exhaust leak and I see the outer cv boot has torn on my mk1 Golf [ actually Scirocco - same thing]
I am thinking I can drop the inner cv joint from the gearbox and work on it in car...... forget that.!
I duck out and buy the 3/4 inch 30 mm socket for that axle nut - turns out it isnt that tight [ could have used a 1/2 inch drive one ].
The local parts dealer has cv boot kit that look great quality for $16 . Super cheap has 30 mm socket 1/2 drive for $8.
I bought a really nice multi point 8mm drive for the cv joint bolts.
it took me about 3 hours of stuffing around - trying to find an easier way. It will take 2 hours next time as I will go straight to it.
I recommend degreasing everything around where you are going to work - I didnt. ... yuck....
1) car on the ground brick in front of tire - loosen 30 mm bolt on axle.
2) trolley jack under frame at pivot point for suspension.
3) scrape inside cv joint bolts using small screwdriver to enable getting tool bit right in there.
4) loosen wheel bolts but leave wheel on. Make sure axle nut is loose but on.
5) undo bolts around cv joint, using jack to raise wheel to turn for next bolt to top.
6) wrap plastic bag around this inner joint if it is ok.
7) remove wheel.
8 ) Mark the bolt head of the top of two bolts that attach the strut to the axle carrier.
9) Remove the top bolt. Put thin screw driver in the hole.
10) loosen the bottom bolt here and pull the top of the axle carrier section outwards. Remove axle nut completely , carefully move brake line out of gromet holder.
11) carefully remove screw driver - supporting axle assemble move out wards just a little and inner cv should fall clear of drive .
to be contd
