Page 56 of 99 FirstFirst ... 646545556575866 ... LastLast
Results 551 to 560 of 981
Thread: What did you fix/replace on your Mk1 today?
  1. #551
    Boronia VIC
    Glad to be of service!
    My white MK1 developed a loose exhaust system yesterday. I think I need to set up an extra hanger.
    Suspect that root cause has something to do with having two wheels in the air at 110 km/h
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #552
    Jan 2006
    Did some work on the 16v this weekend. Car is finally back together again - thank you long weekend! Put the newly ceramic coated dump-pipe on. It looks ridiculously flash with the shiny ceramic coating but the main reason was to cut down on heat in the engine bay, and to make the pipe last longer as well. I suspect it will lose its shine after the first track day.
    Also made up a basic baffle to go over cylinder #1 inlet cam lobe, the one that throws oil straight at the oil filler cap. I have the built in oil-cap/breather set up so under prolonged high revs it ends up throwing a fair bit of oil into the catch can, even though the breather itself is baffled. This should stop a lot of that, the edges are turned down so when you fill with oil it just spills off the sides.
    Now I have to set up a fuel surge tank - has anyone set one up in a mk1?
  3. #553
    Jan 2006
    Nice little ebay under-car surge tank fitted today, was too busy to get pics. Bought a carby facet pump to supply the surge tank, and the facet pump flows the exact amount of fuel as the bosch high pressure pump (but at a fraction of the pressure) - 130l/hr - so it worked out perfectly. You can just see the alloy surge tank from behind the car if you get down low, kind of like a really miniature SLR5000 drop tank Another thing ticked off the list sitting on the dash...
  4. #554
    Nov 2009
    NZ
    Fixed the fuel line we broke the other week (had to get Enzed to re-make the banjo fitting as it was 90 degrees round the wrong way, my bad for not taking the fuel pump down as well) and connected it all up. Airlock had to be removed before we got any pressure happening, but considering the car hasn't run properly for a few years, it doesn't sound too bad.
    Took it for a spin round the block after getting a UVP from VicRoads, went via the local servo where in my excitement I looked at the litres gauge not the dollar value and didn't have enough money on me. Put about 10-15kms on just driving round the locale, definitely got my money's worth from the permit, and another 26 days in which I can 'test' any work I get done.
    So, one step nearer another Mk1 GTi being back on the road full-time. Reading through the roadworthiness requirements, i'm thinking there's probably a couple more things to do before I go for it (and probably find out there's quite a lot that actually needs doing), but overall much WIN from the weekend, and i've still got a big silly grin plastered across my face and can't shut up about the car.
  5. #555
    Jul 2007
    Launceston
    I just got a new engine for mine
    1.8 16v with dellortos *drools*
    Just need to get the thing running...
  6. #556
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by Stephy View Post
    I believe the saying is
    pics or it didn't happen! hahah
    NICE!
    i like volkswagens
  7. #557
    Jan 2010
    Baulkham Hills
    oh my!! did you get the one Ed had???
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
  8. #558
    Jul 2007
    Launceston
    Bah!
    On the monther-in-laws computer, as if i would put engine pics on that - had to get the pics of the MK1s off my facebook page! (check in the tas MK1s thread)
    Should have some in the next couple of days hopefully - then i may just have to start a project thread...
  9. #559
    Jul 2007
    Launceston
    Yah - got his... Got the VR6 off him too (couple of years ago)... So he's had a big part in both my cars now...Top fella
  10. #560
    Jan 2010
    Baulkham Hills
    i really want a new engine 1.8T would be delish... actually.. ANYTHING other than my stock lump would be amazing
