Page 51 of 99 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 981
Thread: What did you fix/replace on your Mk1 today?
  1. #501
    install coilovers and new wheels tyres.still need to adjust the height after installing arches.need to look into getting rear disk brakes set up and i bit consern how does converting from drums to disk may change wheel clearance etc.
  2. #502
    Jan 2008
    Strathfield,Sydney
    wow what wheels are they more pics!?what coilovers did you use?
    fixed my handbrake, driver seat belt, and re glued quarter window hinges
    76 Scirocco
  3. #503
    wheels are Manaray sport reverse gear MJ9 16x7.5-8.5 et33 195/40 tyres. JOM coilovers.my drum brakes are gone from little noisy to extreme.trying to figure out why???
  4. #504
    Jun 2007
    Eastern Suburbs Melbourne
    did you check your bearings? they could be on thier way out/too dry. easy to replace, not expensive either.
    i like volkswagens
  5. #505
    Jan 2006
    Put a notch in the subframe/stress bar so that the dump pipe won't hit anymore, made up a bracket to support the turbo which will hopefully prevent the turbo studs from stretching/nuts coming loose and then blowing out the gasket. Very slowly ticking things off the May supersprint todo list. Have to figure out how to fix the fuel surge issue - damn internal line in the fuel tank has rotted away.
  6. #506
    Jun 2007
    turbo? what? when where?
    details?
    i like volkswagens
  7. #507
    Oct 2005
    Nowra, NSW
    Come to the supersprint for the Nats Jarred and you will see it
  8. #508
    Sep 2009
    Chillaxing in Tas
    Replaced one front guard with a rust free one, pity its blue and car is green
    doing other one tomorrow.
    bout time i did, bottoms of green ones where falling apart, and they where rather beat up.
    Also put the Last tinted window in (yes im lazy )
    Adjusted clutch cable again, think i got it now.
    Paid for Carby monday, if im lucky ill have it friday, if not next week. then she will be running again.
    <space for rent>
  9. #509
    Nov 2009
    Hobart, Tasmania
    Cleaned and re-oiled my air filter from all the filth that had stuck to the old oil in the filter. A slight performance difference was definately noticable!
  10. #510
    Jun 2008
    Rear wheel bearing rginding and whining big time, anyway put a new one in, the old one just fell apart when I finally got it off the centre shaft.
    1993 MK1 CAB ! Work in Progress........
