Results 1 to 3 of 3
Thread: What battery capacity for a 79 GLD?
    Jul 2010
    Coromandel Valley (Adelaide), SA
    Hi folks, have been having some trouble starting the golf lately - it will glow and crank over, but cranks very slowly and it will just continue to crank without firing until the battery runs dead. When jump starting, the car cranks quicker and starts almost instantly, so I've deuced that the battery is either dying or under capacity.
    On my older benz diesels the batteries were 4x4/truck sized, whereas the battery currently in there is a fairly small/'normal' sized battery rated at 400CCA.
    Will try cleaning battery terminals and the starter/solenoid connections to see if that makes any difference, but pretty sure I'm going to need a new battery.
    So what CCA rating should the battery for a GLD be?
    Thanks in advance!
    Dave - 75 B1 Passat LS Wagon - Are you thinking what I'm thinking B1?
    + 1964 Morris Mini 850
    + Numerous MB Finnie Sedans
    Jun 2007
    Eastern Suburbs Melbourne
    I'm not sure what it's 'meant' to be, but I had a 550CCA champion on my old GLD. Never gave me trouble, started everytime!
    i like volkswagens
    Aug 2009
    When on industrial worksites, the ****heads turn the diesel utes over in gear without the clutch, make the starter motor get them rolling with the low compression.
