Results 1 to 5 of 5
Thread: Weird wiring Woes
    Sep 2009
    Chillaxing in Tas
    Weird wiring Woes
    Got a problem with my Indicators,
    When i turn them on or switch hazards the light comes on dash, but no lights around car come on or blink.
    I have even pulled the plug behind fusebox and used a test light on the correct pins to see if i get anything.... i get nothing, is there a way to check the wires are working from switch to fusebox? (ive also tried a different indicator stalk)
    I have tried 2 different wiring looms, and 3 fuse boxs and 4 relays for the blinkers.
    Any ideas? i must be missing something if every combo i tried fails :S
    There is no engine in car atm, surely that would have no effect?
    <space for rent>
    Jan 2006
    Ballarat, Victoria
    My initial thought was that it might be a fuse, but since you've swapped fuse boxes around maybe not.
    Jul 2005
    Newcastle, NSW
    Do you have indicators, it could be the flasher units kaput or connected incorrectly.
    Sep 2009
    Chillaxing in Tas
    i have nothing :S
    Think the flasher unit sits above fuses in slot K? ive tried a few different units.... unless its somewhere else?
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    Ha, dont worry, fixed it
    Turns out the Flasher unit is a 3 pin relay, not 4. and it goes on the far right (for me anyway)
    <space for rent>
