Not sure about the dizzy vacume but i used this retractable claw thing i got from Jaycar to grab it our
Super Extension Claw & Magnetic Pickup - Jaycar Electronics
hey guys so im almost finished doing this 1.1 to 1.6 conversion, its been a super long painstaking job but its finally gettting there. i have a few questions to help me finsh it off.
first of all. the engine has a 32/36weber on it, and im not sure where to run my dizzy vacuume lines any help would be legendary.
second of all. this was a kinda stupid mistake. but i accidentally droped the plastic speedo gear into my gearbox. my idea is to drop all the oil and try and fish it out... is there any other way to get it done? haha thanks in advance for the help
MK1 GLS 3door
A4 B7 2.0T
There's a reason that thing's plastic, it's so when it gets dropped into the gearbox it can safely be munched up and removed via a fluid/oil change.
There should be a vacuum line on the weber somewhere even on the manifold worst comes to worse T piece it off the brake booster line
there are no vacuume lines on a webber 32/36, and there are two vacuume lines on the dizzy, so lost as to what to do. is it ok to run a line off the mani, wont there be constant vacuume and therefor always be advancing???
hey mate i just put my weber on and the vacuum inlet is at the back of it but my line wont reach, so just asking you and anyone else where do i get sucha odd bit of hose?is it better just to plug it to the brake booster hose?
76 Scirocco
ok so you cna just buy vacuume hose from your local auto parts shop like repco. i found the vacuume outlet on the weber. im going ot run the adcance to that. where would the retard been run off? if anywhere? also is it important to use the thermopneumatic valve or can i just bypass it?
yo stent check the back of that carby again i'm 99% sure you'll find a little vac port
i found it where do you think i should run the retard?
