Results 1 to 10 of 17
Thread: weber yo
    Feb 2010
    perth, western australia
    weber yo
    hey guys so im almost finished doing this 1.1 to 1.6 conversion, its been a super long painstaking job but its finally gettting there. i have a few questions to help me finsh it off.
    first of all. the engine has a 32/36weber on it, and im not sure where to run my dizzy vacuume lines any help would be legendary.
    second of all. this was a kinda stupid mistake. but i accidentally droped the plastic speedo gear into my gearbox. my idea is to drop all the oil and try and fish it out... is there any other way to get it done? haha thanks in advance for the help
    Feb 2007
    Quote Originally Posted by cleb View Post
    Not sure about the dizzy vacume but i used this retractable claw thing i got from Jaycar to grab it our
    Super Extension Claw & Magnetic Pickup - Jaycar Electronics
    MK1 GLS 3door
    A4 B7 2.0T
    Aug 2009
    There's a reason that thing's plastic, it's so when it gets dropped into the gearbox it can safely be munched up and removed via a fluid/oil change.
    Feb 2009
    Please Enter Location
    Quote Originally Posted by IH8 View Post
    Yeah right.
    Mar 2007
    South Brisbane
    There should be a vacuum line on the weber somewhere even on the manifold worst comes to worse T piece it off the brake booster line
    Feb 2010
    there are no vacuume lines on a webber 32/36, and there are two vacuume lines on the dizzy, so lost as to what to do. is it ok to run a line off the mani, wont there be constant vacuume and therefor always be advancing???
    Jan 2008
    Strathfield,Sydney
    hey mate i just put my weber on and the vacuum inlet is at the back of it but my line wont reach, so just asking you and anyone else where do i get sucha odd bit of hose?is it better just to plug it to the brake booster hose?
    76 Scirocco
    Feb 2010
    ok so you cna just buy vacuume hose from your local auto parts shop like repco. i found the vacuume outlet on the weber. im going ot run the adcance to that. where would the retard been run off? if anywhere? also is it important to use the thermopneumatic valve or can i just bypass it?
    Dec 2008
    Perth
    yo stent check the back of that carby again i'm 99% sure you'll find a little vac port
    Feb 2010
    i found it where do you think i should run the retard?
