Results 1 to 5 of 5
Thread: weber carby position?
    Aug 2011
    brisbane
    as the picture shows, the carby sits 180deg. to all the webers iv'e seen on golfs. are there any pro's or con's the way it is?
    http://i59.tinypic.com/2mcsg49.jpg
    Dec 2012
    Sutherland Shire, Sydney
    Carburetors can be side draft or down draft - the float chamber is different between these configurations
    Side draft is probably better as it has a direct airflow into the head - but needs a lot more space
    Down draft will put the air flow through an elbow, this configuration uses less space but is taller
    Both work really well for street cars
    In Motorsport there would be a preference for side draft
    But it's mostly fuel injection and ECU these days which is far superior to carburators
    Aug 2011
    brisbane
    Quote Originally Posted by Martin View Post
    sorry, I was meaning on this car the fuel bowl is on the right and throttle linkage are on the left, while all the other down draught weber setups, show it the other way round.
    Nov 2010
    Melbourne - SE
    Quote Originally Posted by ericcs View Post
    I know what you mean, doesn't make a difference dude it's all same-same
    Aug 2011
    brisbane
    Yeah it was just a curiosity question, as the car runs fine.
