would love to take it for a trip and put faces to names
nah been thinking of getting the grinder out they're only
40mm lowered kings might take half a coil off ???
with ya fan bro allways check ya fuses there dodgy, rebend some of the fuse holders or jiggle the fuses, if not try hot wire your fan make sure it is working,
cher
the golf is not dead.
all gone bad eng has huuuuggggeee vib in it
think flywheel not balanced properly??
so bad makes cd player skip!!
have to pull out box on weekend and put my
old flywheel and clutch and see if it goes away
I HOPE!!!!!!!!!!
Are you sure its not engine mount? If the one on the drivers side is gone, it causes mad vibrations.
to check that it's not the thermo switch, touch the 2 connections to the switch together. If it has a connecter, use a piece of wire or paperclip to short it. If your fan is ok, it should fire up when you short the circuit.
Don't worry about blowing anything up - thermo switch is just a switch so by bypassing it, you're just manually switching the circuit!
good luck
Steve-o
had stronger mount made could be to hard
what do you think???????
Fairly solid alright - hope that it's not *too* solid for road use.
I could one of these to stop the lump jumping around on vicious launches
in tarmac 'khana's![]()
gunna try drill some holes in the mount
to see if that helps???
I would - even the after market poly mounts aren't solid - you want *some* give in them - just not too much...
