WOW!!! She looks awesome Tommie!
How are the shaft bushes in the dizzy that can cause breaking down and missfire under load, however I suspect that there are a combination of small things at play here. It's just a matter of finding them all.![Face Palm](https://www.vwwatercooled.com.au/forums/images/smilies/facepalm.gif)
A couple of things that you're probably onto, Cracked dizzy cap, it may look good but a crack can cause under load issues. Is there supposed to be a ballast resistor in the system, Points or trigger playing up, I had a brand new after market distributor in another car (a Holden SHHH!) the advance was all over the shop, breaking down under load, revved freely when in neutral, wouldn't rev past 2500 under load. It turned out to be a combination of the bearing clearances, and a faulty trigger.
I hope my brainstorming is helpful!
Cheers, Scotty.
EDIT: Corrosion on terminals or in wires of the ignition system, check earthing too!
1976 Martini Olive Mk1 2 door Swallowtail
1981 black Mk1 ragtop GTI in need of some tlc
1979 Mk1 2 door - long term project
2002 Oettinger V5 Bora - daily driver
