Hi All,
Still no luck with the car. Running out of ideas....
Again the car starts, idles and revs without too much trouble . As soon as you stick it in gear and under loads the car conks out and doesn't want to run.
Things we've changed.....
1. New spark plugs
2. New rotor.
3. New Leads
4. New Fuel pump ( Bosch 044).
5. Set base ideal ( disconnect both vacuum lines).
5. Confirmed fuel pressure sitting about 4.5-5bar at idle and free revving.
6. Swapped Kjet fuel distributor.
7. Swapped Kjet injectors.
8. Swapped coil.
9. Fresh fuel in fuel tank.
And probably a lot more I can't remember.
Please let me know of any ideas.
