Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 69
Thread: VdubEd's Mk1 Cabriolet 'Felix'
  1. #21
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by VdubEd View Post
    Bummer that's a lot of money! I think I'll have to go for it though, I've spent so much on this rig already it would be a shame not to go ahead with it. Hopefully I can sell the other ones I got to help!
    Thanks rocco, ed
    Did you buy a pair of adjustables? If so I might be interested.
  2. #22
    Jan 2011
    Cammeray, NSW
    I will buy some but things are on hold until I get the fuel injectors out and the motor running well. I'll sell you the other ones now though if you want them?
  3. #23
    Aug 2011
    Gold Coast
    Sorry to jump in but i'm looking for a set of rear lights like yours. were they on the car when you got it or do you know where to get some in OZ?
    Thanks
  4. #24
    Jan 2011
    Cammeray, NSW
    No mate I got them online from Deutschland. Do you want me to dig up the seller and send you his details? Not sure if you can get them in oz
  5. #25
    Perth. WA
    I use a long large screwdriver and lever against the rocker cover. The flat end of the screwdriver needs to be positioned under the fuel line nut if you can get it. Otherwise go between the nut and the ferrule at the end of the braid.
    Apply firm consistant pressure downward towards the front of the car on the screwdriver, use your other hand under the injector to stop the driver pushing the injector towards the inlet manifold. they are a bugger with old dry seals but they will come. Careful you dont stab yourself with the screw driver as well... maybe I should do a video ??
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  6. #26
    Jul 2005
    Newcastle, NSW
    PM me what you're after for them and I'll consider what I'm up to.
    Progress on injectors?
  7. #27
    Jan 2011
    Cammeray, NSW
    Progress is slow at the minute, new job and i'm doing quite a bit of charity work on the weekends. I'm hoping to have a look this evening.
    I had a mechanic friend look at it during the week to see if he could get them out, he said he'd never struck one this hard and I was on my own for this one! So I'm not expecting much luck.
    PM sent
  8. #28
    Jan 2011
    Cammeray, NSW
    Woo hoo, ok so I got the little buggers out.
    Thanks for all the advice guys... Now for the new seals and hopefully she'll be running sweet again.
    (Check out number 4 that was the leaky one, the seal was gone, you. can tell from the photo)
  9. #29
    Jul 2005
    Newcastle, NSW
    Well done but these things are never that easy!
  10. #30
    Aug 2011
    Gold Coast
    Please if you can. I have seen some on UK ebay so thinking about grabbing them 50 quid plus postage, which im sure will be the same again.
    Thanks
