Hey Ed,
with the car running ( idle) close the throttle switch ( close the full throttle switch only, not open the throttle) if the idle rectifies itself then the ox sensor is toast or the wiring to it is damaged.
I changed my K E Jet back to K jet basic, runs way better ( no cat convertor, lambda or ECU ) Installed a TT 268 cam, 2 1/4" exhaust, Mk3 ex manifold and TT downpipe. Still needs to go back to the dyno tho. Stock tune was about 68 HP at the wheels ( 1.8 JH with Aussie emissions, 100k on the engine.) I know the 93 has a idle boost circuit as well, will dig out the relay number so you can check if the 90 has it fitted.
If your needing the KE parts I have all the electronics + wiring harness saved.
HTH
Pix fixed
Lots of MK 1 Scirocco's...
Cheers,
Grant...
