I will buy some but things are on hold until I get the fuel injectors out and the motor running well. I'll sell you the other ones now though if you want them?
Sorry to jump in but i'm looking for a set of rear lights like yours. were they on the car when you got it or do you know where to get some in OZ?
Thanks
No mate I got them online from Deutschland. Do you want me to dig up the seller and send you his details? Not sure if you can get them in oz
I use a long large screwdriver and lever against the rocker cover. The flat end of the screwdriver needs to be positioned under the fuel line nut if you can get it. Otherwise go between the nut and the ferrule at the end of the braid.
Apply firm consistant pressure downward towards the front of the car on the screwdriver, use your other hand under the injector to stop the driver pushing the injector towards the inlet manifold. they are a bugger with old dry seals but they will come. Careful you dont stab yourself with the screw driver as well... maybe I should do a video ??
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Progress is slow at the minute, new job and i'm doing quite a bit of charity work on the weekends. I'm hoping to have a look this evening.
I had a mechanic friend look at it during the week to see if he could get them out, he said he'd never struck one this hard and I was on my own for this one! So I'm not expecting much luck.
PM sent
Woo hoo, ok so I got the little buggers out.
Thanks for all the advice guys... Now for the new seals and hopefully she'll be running sweet again.
(Check out number 4 that was the leaky one, the seal was gone, you. can tell from the photo)
