![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
VdubEd
Thanks rocco, I had a bit of a search and came up with this from previous posts:
These are the prop valves in the thread.
but i have these adjustable ones, from Mk2 that i have. The closing pressure says 35 on the valve, but i am assuming that by adjusting the these mk2 valves I will be able to get the Bias correct? as they are loaded to be adjustable dependant on the load on the rear? When i bought them in UK the guy who sold them to me seemed pretty sure they were the right ones for the job, i hope so anyway?
![](http://www.vwwatercooled.com.au/forums/images/imported/2011/11/N306055323-1.jpg)
Not sure about using the axle adjusting valves as pictured. You will have to do more research. Gotta remember the MK1 is a lighter car than a MK2, Although the cabrio is heavier than a std Mk1. Have a read in the manual and see if the Mk2 valve you want to use is adjustable, I am under the impression all you adjust is the preload on the lever with the spring position ??
Could always try using a pair of adjustable valves and trial N error ??
Lots of MK 1 Scirocco's...
Cheers,
Grant...
