Results 1 to 10 of 11
Thread: URGENT: 1.8 8v alternator needed!
    Oct 2014
    So my car stalled, twice, and by then the battery was flat. preeeettttty sure I need a new alternator -.-
    Any advice on how to be certain of this? I'm quite confident that the alternator is bust, but maybe I can breath new life in to it!
    Otherwise, anyone got one/where could I get my hands on one?
    Gosford Central Coast NSW
    try an autoelectrician.
    there are a few simple things you can do to test if its charging or not. do a search you will find heaps of info on the web about it.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Feb 2006
    Melborune, VIC
    Get a multimeter and see how much voltage it is putting out. Should be well over 12v (14v is optimal)
    If it is the alternator, try replacing the regulator first
    May 2011
    Albury, NSW
    I have a 1.8 8v alternator - it came off a car with A/C - not sure if it'll be okay on a car without A/C - i'll let the other chime it. Works fine though, needs a new belt that's all.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Oct 2014
    might try just giving RACV a ring and letting them test it, I don't imagine that I'll have to do this regularly and I don't own a multimeter.
    thanks for the heads up though guys, again if anyone has one I will probably be looking to grab it.
    Cheers.
    Oct 2014
    @NightPhotographer - Cheers mate, if it works with a non a/c motor then just pm me a price. I'll check the life of mine/local area first and let you know if I need it.
    Jan 2012
    St Albans, Victoria
    I might have one for you bud. And I'm in Melbourne
    Contact me on 0422766559 if you wish.
    Oct 2014
    turns out that the idle was so low that I was slowly murdering my battery with my stereo -.-
    live and learn...
    Quote Originally Posted by Mk1DUB View Post
    Cheers.
    You own a Mk1 but don't own a multimeter, come on it's only $25, you'll find it's the best tool in your garage.
    Aug 2011
    brisbane
    for the record, the mk1 cabby uses the mk2 alternator, like a lot of other parts!
