Results 1 to 10 of 15
Thread: Upper Strut Bars. Which is the best material? Steel vs Aluminium.
    Mar 2011
    Bunvegas, Western Australia
    I posted this in the Wheels & Suspension forum but I haven't had much feedback so I figured i'd post in here to see if anyone else has a bit of an idea.
    So which would be better? A steel 1piece upper strut brace, or an aluminium one? I realise aluminium would be a lot lighter, but wouldn't it flex more? Thus negating the purpose of a strut bar?
    Cheers for any input
    Oct 2010
    Melbourne, VIC
    Steel for sure, especially if it can be an alloy steel like 4130, though you'd need to heat treat it after fabrication.
    Some of the aluminum ones are a joke and only good for pose value - you can bend them by hand to get them to fit the strut mounts!!
    Resident grumpy old fart
    Point Cook, Vic
    it depends on the grades of steel or aluminium used.
    FOLLOW US ON FACEBOOK
    Oct 2010
    Melbourne, VIC
    I have pretty much zero confidence in the aluminum strut braces having seen a few. Either the grade of aluminum is non-structural (ie unalloyed) or the braces have not been heat treated after being welded together which gives you an expensive stiff brace with brittle welds and soft alloy around them.
    A mild steel brace may well be heavier but is guaranteed to be stiff and strong if the weld look even remotely passable and the gauge if the steel is enough that you can't deform it by squeezing with your hand. High strength alloyed steel needs proper heat treatment as just as alloyed aluminum does.
    Point Cook, Vic
    I cant say that ive ever seen even a cheap chinese one fail except from overtightening an adjustable one.
    You talk as though the cars have zero structural integrity as standard and that the load on the bars is huge. Your car is not made of cheese. The strength of the bar its self is not always proportionate to the strength of the structure it creates
    Oct 2010
    Melbourne, VIC
    But that's the whole point of the exercise. The body is quite rigid, especially with the firewall welded just behind the strut mounts so any deflection is going to be quite small - it's the distance to the LCA that acts as a multiplier for effect on the suspension geomtry
    Now force will be proportional to deflection and rigidity so if the brace isn't very rigid, then it won't apply much force back against the deflection caused by the relative strut movement. The resultant movement will attempt to compress the brace which is going to be pretty good no matter what the material EXCEPT that the length of the brace means that it will bow and a floppy length of aluminum isn't going to resist the bowing to any great degree over the sort of movements we are discussing.
    For an underbrace, where the deflection results in a net tension, a cable would work as long as it was very stiff in tension.
    Point Cook, Vic
    It is a common misonception that an upper strut brace is under compression during cornering. They are actually under tension. This being the case your above argument is actually not valid.
    Its mostly above my head but this article may explain it for you a little better.
    Isn't a strut tower bar under compression?
    Jul 2005
    Newcastle, NSW
    My personal experience from MK1's are with steel. I don't think that the weight saving is worth messing about with alloy for in this application.
    Mar 2011
    Cheers for all the points guys!
    I'll have to have a read through that article you posted as well Tim. It's gotten me interested!
    Looks like steel is the go for me then!
    Point Cook, Vic
    If you havent done the lower bar then that is the one that makes a nice difference on a mk1 I think especially given they have no traditional subframe. If its steel youre after then TPR Engineering sell them
