Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Upgraded Brake pads for Mk1
    Feb 2007
    Late mk2 gear does not go on to a mk1. You need to find early 16v stuff if you want to plug and play on the mk1.
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2006
    Ballarat, Victoria
    I don't agree with the description that all Mk1 brakes are woeful.
    I've found that good quality pads and rotors give quite reasonable braking on a standard Mk1. My suspicion is that cheap components are used and then the design is blamed. (I've been caught with some brake places selling me cheap pads when I wanted quality - can sell them to you cheaply if you want them)
    My daughter's GLS are running some ATE pads that I sourced from volkspower and the braking is fine (about$70).
    I use Ferodo DS2500 on the GTI that I sourced from Melbourne Performance centre in Bayswater and the braking is excellent (about$200).
    Dec 2007
    Somewhere in Melbourne, Victoria
    see if you can get a Mk1 GTI or later model Mk1 Cabrio Servo, caliper and disc set as the have bigger pads and ventilated discs.
    Worked a treat on my first Mk1, never had brake fade!
    Great to hear you're back on the road Ben.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
