What do you guys recommend as an upgrade to improve on the (already) woeful disk brakes on a Mk 1.?? EBC Greenstuff and if so, where is the best place to buy them in OZ??![]()
Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
Green stuff would probably make the brakes worst are they have a very low friction co-ef when cold, and don't get alot better when hot... Decent standard street pads would probably be a better option than going to the Greens. What pads are you currently running?
As has been said, you'd be better off sourcing Mk2 gear, but if you really don't want to go down that path (and you're sure your current setup is in good condition) we could look at getting some high friction pads made up...
GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
Yes I would deffo check you have no airleaks to servo wise. Always makes sure rear shoes are well adjusted. Bleed the brakes and put new fluid in, get rid of all air leaks. Then finally a set of braided hoses on the front would give a bit better peddle feel and a firmer stop.
I would do that before sourcing expensive pads. At least do the things that cost next to nothing, system check....bleed etc.
1993 MK1 CAB ! Work in Progress........
+1 to all that!!!
The only time braided lines give you better pedal feel over new rubber lines is when your fluid is boiling, and that's the fluid's problem, not the brake lines. Braided lines make very little difference over good condition rubber ones, and the majority of the improvement people get when fitting them comes from either fitting new brake lines full stop (be it rubber or braided) by replacing old ones, and/or having new fluid flushed through. Not necessarily anything related to the fact that the lines are braided.Then finally a set of braided hoses on the front would give a bit better peddle feel and a firmer stop.
We can get a custom set of higher friction pads, in something like a LTM003 or HPX made for not much more than $100...I would do that before sourcing expensive pads.
I'm running the Lucas/TRW pads on my MK1 and they seem fine to me for both street and track.
Mind you the rest of the system comprises of
- GTI Ventilated Discs & Audi 80 Calipers up front
- MK3 Discs at the rear
- Braided lines all 'round
- MK3 Booster
- 22mm Master Cylinder
- 16v Scirocco Proportioning Valves
Best thing to do with MK1 brakes is just to replace all the old stuff with new stuff. MK1 brakes were pretty good when the car was brand new. They're not bad by design, they're bad by old age.
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
I got a complete MK2 setup (rotors, calipers, pads etc) from GTI Imports and it was cheep and has seen racetrack time and is great. That is how I would go.
MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
"Fit the gearbox ya bum." Loon - best post ever!
