simple things first - the fuse for the fan should be a 16 amp at least, and is the last fuse on the right hand side of the fuse panel. golf 1 fuseboxes are notoriously bad and theres every chance that if you push, wiggle or replace that fuse (even if not burnt out) your fan may begin working.
i would next check the switch as ontarv suggested.
provided that coolant flows into the bottle through the little pipe at the top when the engine is running and settled, your water pump/etc should be fine.
checking the thermostat is also easy. undo the bottom radiator hose at the pump end, and undo the two 10mm bolts that hold the bowl shaped fitting to the base of the water pump. the fitting will come off, and the thermostat sits between that fitting and the water pump. stick it in a pot on the stove and make sure it opens - you might be able to find written on the thermostat what temp it should open at, but its probably between 80-90 deg C.
good luck
aydan
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
