1300 to 2000 alfa Romeo twin cams used twin 40 dcoe webers and later 2ltmotors had dellortos. 40mm alfa carbs off a 1600 should suit as choked and jetted
Any body have any idea on whether I would be able to run twin Weber 40's on my 1.6L 8V? I know (& speaking with a gentleman at my work who's an engineer & is fairly familiar with carbs) that some of the older 1.6L Fiats (?) ran dual 40s?
So i'm just interested in seeing what anyone else thinks about running dual 40s, or perhaps if I should run dual 38s?
Thanks!
-Byron
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
Resident grumpy old fart
Totally possible, looks awesome too,
Might be better if you used a bigger engine (such as a later 1.8 or 2.0 from a MK3) as twin carbs are a bit of overkill on a 1600
Formula 3 1600 Golf motors run 48 mm Webers for 190 to 200 hp.
Crazy motors those formula 3's
Im running twin 40 sidedraught webers on a 1.6 8v as we speak. They have tiny choke sizes in them though -28mm. Need to be bigger. Still, tuned right they run very smoothly, economically and are great funthe noise they make is addictive
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
