Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 141
Thread: Turbo Diesel Cabriolet Project (with head porting pics)
  1. #61
    Gosford Central Coast NSW
    Finally found someone local to machine my flywheel, so I (again!!!) changed the flywheel yesterday for the original, now properly machined and lightened a bit to be just under 5kg (stock weight is around 5.8kg).
    Working towards running it in the Nationals Supersprint, so a bit of work to do to make it nice and tidy in aid of a day of reliable running
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #62
    Well, its 4 times I've had the gearbox out now since the engine swap - needless to say I'm getting pretty damned good at it and also pretty damned sick of it.
    Anyway, finally its running smoothly and once the flywheel and pressure plate are bedded in the clutch should hold too.
    While I had the gearbox out, I took the oportuninty to do a few other things in aid of the upcoming supersprint. First, I swapped out the standard master cylinder for a later model 22mm one and associated booster. Also, I replaced the steering rack mounts with new red poly mounts (wow what a difference that makes!) and put a new (adjutstable) tie rod on the passenger side.
    Tomorrow morning I have a 5 speed shift linkage kit to go in to make it "good as new". Basically, I'm just concentrating on replacing and refreshing things to make it reliable as opposed to fast for the supersprint - if I can go out and run it all day I'll be more than happy
    '99 A4 Quattro 1.8T
  3. #63
    Jan 2006
    Great, looks like you are on track for Wakefield. Those poly steering bushes do make a difference, makes you wish they never moved away from the solid rack mounting in the early golfs!
    The best thing to do with our old/modified cars before a supersprint is just get them out and drive them a bit and hopefully flush out any bugs. Thats the one advantage us guys with still-registered cars have.
  4. #64
    Indeed - took the car for a bit of a drive just now and man those bushings are so much better. So much, infact, the gear linkaage assembly moved (rotated) up quite a ways, putting the adjustment way out and causing the selector arm to foul on the turbo intake pipe, where before it cleared!
    Anyway I modified the selector arm to give it enough clearance for the turbo intake pipe and made a new bushing for the main shift rod and its beautiful now.
    We'll be driving the car all week commuting to work as I now have to try and run in the clutch assembly.
    Your not wrong though mate - nothing like a lot of driving to bring all the little bugs to the surface!
    '99 A4 Quattro 1.8T
  5. #65
    I promise a video tomorrow, but for now, let me just say....
    WORKING TACHOMETER!
    '99 A4 Quattro 1.8T
  6. #66
    Jun 2006
    Orange NSW
    Nice work, dude!
  8. #68
    Jan 2008
    Sunshine Coast
    Yeah, good to see someone from the old crew keeping the diesel tinkering alive!!
    I've gotten so darn busy, but in a good way!
  9. #69
    Apr 2006
    Melbourne, Victoria
    Nice work Aydan!
    DId you use the "W" terminal technique? How did you go about calibrating it?
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
  10. #70
    I bought a laser tachometer from Jaycar to measure the engine rpm. I have a mk2 90amp alternator which already has the w terminal, so that part was easy.
    I simply connected the tach up to the alt, +12V and gnd (while it was still out of the dash) and then adjusted the varistor to calibrate - easy! checked it at a few different rpms and found it to be as accurate as I could discern from the needle, so no probs there!
    '99 A4 Quattro 1.8T
